Water Pump bolts question
Joshua Keith
Memphis
Joshua
1985 K10 SBC350
Short Water pump
Replacing the water pump and didn’t notice the different length bolts....Rookie mistake. I have 2, 2 inch bolts And 2, 3 inch bolts. Lengths estimated. I can’t figure out which went where. I would think The shorter bolts would go at the bottom because they’re in the water jacket but I’m also hesitant putting the longer bolt near the #1 cylinder. And if I look online kits come with 3 short bolts and a longer one. Can’t find a diagram for it. Thanks
Two things:
1: It should be a "long" water pump.
2: Every SBC I've ever messed with, all four bolts were the same length.
Joshua Keith
Memphis
Joshua
Two things:
My apologies, it is a long pump. The PO must’ve thrown in different length bolts for some reason. I’ll just find some new bolts all same length to throw in there. Thanks
For the best, especially when dealing with water jackets. IIRC, my ford 300 had 2 bolts out of the whole mix that were special length and went into the water jacket, special lengths, the rest were the same. Annoying design choice..
brentjo
