Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
Ok guys I noticed my padding wet yesterday, removed it and the mat. So it's clean bare floors, well rusty ones LOL. Today and last night it rained, floors are wet, pass. side more so then anything. Truck has ac, no motor or trans in it, ac box intact from what I saw. The bottom of the inside heater box is wet, and it seems to be running down from one corner, dripping into the floor.
The driver's side seems to be droipping down from around the booster or steering column.
Is there anything under the outside cowl, I should look for? like a flap, vent or something besides the normal like rust holes?
I'm not sure if it's maybe the seal between the booster and firewall, or maybe between column bracket and firewall?
Same for ac box not sure if it's box getting full of water, or just seal between it and the firewall.
I can't put it in the garage to keep it dry right now, and I doubt I can take anything apart to fix it right now since the weather is getting bad. I may have to try taping some plastic to my front window and down to the hood to stop water getting in the cowl area.
