Washer fluid motor not working
FireTruck1984
Michigan
1984 and 1984
Washer fluid motor not working, is there a separate fuse? I don’t see one marked , only wipers
‘84 C1500
MisterB
Northwest
AJ
GMC K2500 4X4
Not sure, but those motors are notorious for being junk and going out. One of the best mods you can do, is to take the reservoir out of an 88-91 Chevy/GMC truck. The motor is built in to the reservoir. Just bolt in the reservoir, splice in the wiring under the hood, attach the rubber fluid lines, and you're done. I think I did a little write up a while back on that with pictures if you search
Sent from my SM-N975U1 using Tapatalk
bedwards
Adger, Al.
Bryan
c10 Silverado
I had to replace mine which was in the reservoir. I got a Delco at Rock Auto. After I got the old one out, I could tell it had dried washer fluid stuck in it. I cleaned that out and now it works too. Might pull yours out and see if it is stopped up and or stuck.
FireTruck1984
Michigan
1984 and 1984
I will try that, Thanks
Patrick Sharkey
Salem NH
Patrick
I had a similar issue on our '84 K10 truck. I bought the windshield wiper pump repair kit on Rock Auto and that fixed our problem.
any two wire pump/reservoir from GM or ford from the time should work. I gave my dad my 1988 oldsmobile cutlass reservoir which had flush tabs on one side(easy to mount) and a 2 wire pump. and the pumps can be bought new. and you can put the reservoir anywhere you want.
not gonna use it since would need a right angle bracket or it would stick out weird(maybe ok ig) but heres an example from 88-94 century/cutlass calais
jlyon1006
