Wanting 4" suspension suggestions
Chris64
San Diego
My K-20 currently has a 2" lift. It came that way. I assume it's aftermarket leaf's up front and it has 2" blocks in the back (I looks to maybe also an add-a-leaf in the rear).
That said, it's a bouncy ride. In summary, my two questions are;
I need to lift it a little more for my tires. Is there a good choice for a better ride?
Is clearance a problem with 35" tires and a 4" lift?
The incoherent rambling version:
I'd like to get a full suspension front and rear to remove the unknowns of what's currently on there. Also to get the little arm to align the steering box would be nice. The cross-over steering looks interesting but that's too much to tackle right now.
The front fenders were cut (poorly) for clearance. I'd like to get new fenders but I need to address this clearance issue. I'm under the impression that with 35" tires and a 4" lift I should be OK for clearance. But I was really hoping to find something that was a little softer (I've seen Tuff Country EZ-ride or Sky Jacker soft-ride mentioned). I currently have Sky Jacker 8000 shocks for a 2-4" lift. They work but I'm guessing those are not intended for a smooth ride.
I'm not towing with this. I know it's a 3/4 ton but it's just a cruiser and maybe a light off-roader for me. I've read mixed thoughts on blocks in the back. They tend to ride softer, but not as good for off-roading. Since I have mystery leafs in the back I'm not sure.
Thoughts?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Thoughts?
For leaf springs you could get ORD Custom, which are produced by Alcan. Double check all the measurements from main eye to centering pin, as I was shipped mismatched springs.
Another option is Deaver.
A long travel soft spring in a 4” lift may require some trimming with 35s if you are using all of the up-travel. Consider having the centering pin relocated further forward on the front springs to keep the tire off the firewall.
Chris64
San Diego
...Consider having the centering pin relocated further forward on the front springs to keep the tire off the firewall.
How big of an effort is that? I'd probably need a longer drive shaft and the pitman arm, correct? I like this idea in spirit.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Potential fitment issues with the 35s depend a lot on wheel choice (width and offset/backspacing) and tire choice, if it is a true 35” tire or 34.5” tall, mud terrain with a very aggressive tread and sidewall or an all terrain with more of a highway pattern.
I’m not personally experienced with lifting these trucks, but I believe crossover steering begins to be recommended around the 4” lift mark.
ORD does sell “zero rate” add a leafs and an offset centering pin plate to move the axle ahead or behind the stock pin location.
Chris64
San Diego
They're 35x10.5 BFG AT on 10" wide wheels with a -22 offset - so they're wide-ish.
Wouldn't moving the axle forward an inch require other mods? Or is that within the axles allowable range. Also the steering arm would need to be longer, or maybe just adjust it way out (safe?)
Zelph
Nevada
Cheap would be Tuff Country EZ Ride. My experience with these is that they do ride pretty decent for off the shelf.
I’d plan to buy some extended brake lines too, at least for the front.
If you move the front axle forward you will need to cut the fender fang.
bruisedbanana79
San Diego, CA
Jeff
Suburban
I will add that I ordered a 4" kit directly from Tuff around black friday and was told it would ship 1/6. I finally cancelled my order last week after every week calling them a new part was short from my lift kit. They would pull items from kits to push out single piece orders. I ended up going with a BDS kit from Jack-IT.com and it was delivered within two days after ordering, now I can not state how the BDS springs are but from other reviews they appear to be a great choice.
RattleSnack
Ford City, PA
Bill
D30 M1028 CUCV
6.2 Diesel
Mine has 4" Skyjacker C140S softride front springs, ORD HD front greasable shackles, 4" lift blocks in the rear with factory springs, and Rancho 5000 shocks. Tires are 315/75/R16...so they are just about 35 inches. No rubbing...no fender trimming needed. I really like how it rides down the road. Being it's a CUCV D30, it has 56" springs in the back, so that also helps give you a better ride vs. 52" springs on the 1/2 & 3/4 tons.
Chris64
San Diego
Well the price is certainly right for these.
Of course that's lacking the U-bolts and I'm not sure if those are really front or rear. I should probably get new shackles as well. The front brake lines are already good for 4" lift but the rear is stock length and it's already sketchy with a 2" so I planned to replace it (again - one of the first things I repaired).
I checked mine out just for reference. the front is about 47" bolt to bolt and it's a stack of 6 leafs. The rear is 52" and it's 6 leafs and a thick add-a-leaf. I'm not sure if the rear is stock since it does have a 2" lift block on it.
My quest for parts is on.
RattleSnack
Ford City, PA
Bill
D30 M1028 CUCV
6.2 Diesel
Yeah....that picture from Amazon is way wrong. Here is an actual picture of the C140S front springs:
The springs come without bushings...so you would need those as well. OffRoadDesign.com has both greasable and non-greasable bushing kits. All of there stuff is pretty top-notch, in my opinion.
Chris64
San Diego
OK, so I'm still trying to figure out the optimal setup and I'm worried that a 4" lift just isn't enough for 35" tires. I don't want to go smaller on the tires.
So what are your thoughts on a 6" lift?
Optionally I was thinking about maybe still doing the 4" and modding my fenders to still be cut but just not looking like they were cut. The main problem there is my welding skills which are just barely functional, especially on thin body metal.
77 K20
Montana
K20 5" lift
HT383 fuel injected
How much are you planning on twisting up the truck off road? The more articulation you have the more room in the wheel wells you need. If you keep the factory sway bar on then that will limit how much articulation you will get. Removing the sway bar or adding sway bar disconnects that can pivot will make it a smoother ride though.
And you should move the bumpstops down- preferably with aftermarket ones. This will help prevent the tire from being stuffed too much into the wheel well.
RattleSnack
Ford City, PA
Bill
D30 M1028 CUCV
6.2 Diesel
Agreed. If you're planning on street-driving with some light off-roading, a 4" lift with 35's should be fine...as long as you don't go crazy with offset wheels and spacers.
Now if you're looking to do some more hard-core type wheeling, then yes...you will need more room in your wheel-well...which means more lift, and/or fender trimming.
retirednow
