Vibration
Randy Terry
Shaky
85 Chevy short wheel base has slight vibration from 55 to 65 miles per hour, it doesn't seem to be in the steering wheel you can feel it through the seat. Any suggestions?
dvdswan
Port Orchard, WA
Dave
Wheel balance or weight fell off, U-joint going bad, sticking slip joint in driveline.
K201979
Winona, missouri
Hippie
350ci
X2. My first guess would be rear tire out of balance. Check wheel weights but also look for mud in rim, rocks in tread. If its the truck in the pic, i doubt it sees much off road:) but you coulda picked up a rock or a nail in the tread, on the street. Also check for missing weights on the driveshaft. Happy hunting!
dvdswan
Port Orchard, WA
Dave
I thought of the mud too and saw the avatar and thought mall crawler. LOL
The vibration just might be from his name too. :)
Randy Terry
Shaky
Lol, thanks for the info.
350 w/203
Go for a long drive with your GF at 60 MPH. I'll bet she can tell you where the vibration is coming from.
Randy Terry
Shaky
Wow, that might just work may want to keep the vibration instead of getting rid of it.
K201979
Winona, missouri
Hippie
350ci
Nah, get rid of the vibration and find some washboarded gravel roads when the need arises:anitoof:
350 w/203
Craig 85
Nashville, TN
454/TH-400/NP205
I had one on a C30 crew cab. When I bought it, it had this chirping sound coming from the torque converter. Being young and dumb back in the early 90's, I just tightened the bolts. Problem solved...
I then got a harmonic vibration at around 60+ MPH. Turns out the flex plate bolt holes had wallowed out and put the torque converter out of center just slightly.
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
If you choose to get rid of the vibration, here's what i do when chasing a vibration. First determine if it's engine speed related or vehicle speed related which in your case it probably is. When it's vehicle speed related i check if the vibration is still there when coasting or when in neutral at the vehicle speed the vibration normally occurs. If not it can be anything from the driveline from engine to diff or axles. If it is still present, it will probably be tire related (balance or out of roundness).
jlyon1006
