ChuckN
- Nov 8, 2022
- Bellinham, WA
- Chad
- C10
Well @Ricko1966 not sure that the umbrella seals are going to be a good fit- passing them through the valve springs to check for clearance they seem to rub and hang up quite a bit. Seems like they’d get chewed up.
Turns out there were no seals at all on the exhaust, just the o-rings at the retainer.
But I think you were onto something about the springs being matched to the camshaft- or at least potentially. I found shims located on the springs seat. You could tell me I’m wrong (I’m wrong most times) but what I understand is that shims are used for aftermarket springs to achieve the correct seat pressure and installed height. Any input?
