- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I looked in the book, but there isn;t anything much in there. Just make sure you have your PCV valve hose going to the base of the carb. You can get rid of the EGR hose. And watch your breather hose. Some chrome air cleaner kits come with a base that has a port built into it fo that hose. And if ya got a hose running to your distributor you need that hooked up too. What else....hmmm... I think the rest is just emmisions crap. OH, and one might be a MAP hose, and if it is you definately need that. Like I said, we need to see what ya got there to help ya out.
hahaha, now I go back and read the posts, and just the things I was saying, about these guys that just say or think all those vac lines are junk or smog crap, yada yada, and look who we got saying, you don't need that EGR hose and that....
Actually EGR, Exhaust Gas Recirculaton, isn't all that bad either. It also is hooked to a TVS so that it does not work when the motor is cold. But it does recirculate a portion of the exhaust gases back into the intake system. I am doubtful it causes any loss whatsoever in hp, but it can cause a poor operation condition if the pintle gets stuck open. Which is common to happen when carbon builds on it. So its not a bad idea, say when ever you change your spark plugs, get in the habit of removing your EGR valve and cleaning the carbon off it and make sure the pintle is moving freely. There has also been claims that a proper working EGR system will improve mpg a little bit. Reason being, the heat from the exhaust being recycled in the intake helps vaporzie the fuel better therefore a better more potent explosion in the combustion chamber. How true?, I don't know. It sounds good on paper though.
