Used a drill to check speedometer forgot I had drill on two and the speedometer spun all the way around
wildone454
wv
cody
used drill to check speedometer drill was in 2 speed and it jumped my needle all the way around I put drill back on 1 and seems to be working right running around 25 on drill is everything going to be okay and work properly or will I have to order new speedometer
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have used a 20v Dewalt cordless drill to check the function of the Gear Vender on my car. It’s designed to automatically engage at around 45mph, the drill makes it easy to check. Right at 45 mph you can hear the solenoid click.
Anyway, my drill will easily put the speedometer needle at 115. I’m guessing your speedo is fine.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
If it's still reading, it's probably fine. Just don't push your luck.
sqrbdy
