Upper Front Shock Mounts
firebane
Calgary, AB
Curtis
Can anyone explain why at least on my truck why they designed the shocks so it can slide back and forth on the sleeve for?
Is this so that when the truck flexes the shock can move so it doesn't bind? But then why isn't the rear the same way?
This seems like a silly idea.
It shouldn't. Something is wrong there.
firebane
Calgary, AB
Curtis
Well I put new shocks on the truck and it looks exactly like it did with the old shocks. The only difference is that I can take the top of the shock and slide it on the sleeve.
Can someone provide me a picture of what their upper shock mount looks like please.
Don5
West Virginia
Don
k15
Here is a pic of mine. Now I have a double mount setup. The inner shock is tight between the frame and the original mount. I don't know if you can zoom in close enough to see it though.
firebane
Calgary, AB
Curtis
Hrm. The only reason the old one didn't slide was because of the bushing was stuck to the shock.
This is dis-concerning and uncool. I need a single shock setup so I can see if the shock is tight to the frame or tight to the bracket bolt side.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I know my shocks were mounted solid against the shock bracket and the sleeve was against the frame. That being said, mine weren't factory so, maybe the last guy did it right hopefully
firebane
Calgary, AB
Curtis
well that gives something to work off of
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
My 79 is the same, shock against the shock bracket, but instead of a sleeve it has a spacer.
firebane
Calgary, AB
Curtis
Thank you sir! That definitely helps. I'll see what I can find for some tubing to make a spacer.
firebane
Calgary, AB
Curtis
So cleaning up my shop I found this odd looking black spacer. I then realized it looks like it is for the upper mount.
Went out to the truck and sure enough it fit. So pro comp actually ships a shock spacer to take up the extra space for our trucks. the box was partially open when I got it so it must have fallen out.
Camar068
10 yrs Air Force
So similar situation and getting ready to install. Upper mounts were bent in to accept cheaper shocks (guessing). Not knowing any better, I hacked off the "excess" on the new shock sleeves. Should I mount them if they'll fit (coil overs) or should I get replacement sleeves for the top of the shocks? Single not dual. 86 k10.
5 minutes after hacking them off last year, I searched and found there's a gap between the top and the frame. Have felt like a DA since.
Thx In Advance
zapattack
