Update: The surging stopped....took me by surprise
nycxjeremyy
Midwest
K5 Blazer
6.2 Detroit Diesel
A few of you may know me from my 6.2 posts about my motor surging, well, it stopped....I powered it on today and it ran without it surging.
It would usually surge after 10 minutes, 1 hour later and it's acting normal, the ONLY thing that puzzles me is this:
It does do a TINY bit whenever I'm at a high speed and then let go of the throttle
- full throttle to like 45ish (Or a decent speed)
-let go of pedal completely
vroom...vroom..... idles/runs normally
Other than that, it's running normally??? I'm glad it's fine but still, took me by surprise
(Note: it has warmed significantly since my previous post, it's now 45°F compared to -5°F)
Idling: https://photos.app.goo.gl/k6Z2jBduBCJy6iAu8
Under the hood: https://photos.app.goo.gl/571CfUtfh8xz8hEP9
(Edit: it still struggles to start, even with the new batteries, it'll crank well and then start/turn over, but then it shuts down completely, and I'd have to restart the cycle process hoping it starts, its weird. Not sure what that is)
backwoodsman
Idaho
GMC Suburban K1500
6.2L diesel
You never responded on the other thread. Did you ever check the fuel return line to see if it's plugged? Is any air getting into the fuel lines?
nycxjeremyy
Midwest
K5 Blazer
6.2 Detroit Diesel
I have yet to check that, now that it is significantly warmer outside I will
jjrussell88
