U-Joint Study - Greaseable vs Non Greaseable
85K10
Florida
James
Thanks
Again the forum has come through. Thanks for the info guys will get some ordered today. Thought while I had front end apart might as well do those also.
I just got caught up in here, good **** guys.
85K10
Florida
James
Ordered
Well I got them ordered today from 4wheelparts.com for 60.00 shipped. Thanks for the help everyone. Now i'm ready to tackle my front end job.
Are my rear axle u-joint caps 1.79"? :help:
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
I posted this info on FSC, I think it fits here nicely, since there have been questions about part numbers, and most of those types of questions will involve axle swaps.
14B U-joint info:
Universal joints: Swapping a 14 bolt in place of a 10 bolt can get a little tricky to some because of the possible need for a conversion U joint. All 14 bolts that i have seen, both SF and FF, use a Spicer 1350 U joint. With this said, GM doesn't commonly use a Spicer 1350 joint on 1/2 ton trucks, most commonly they use a Saginaw S44 joint. I have however seen Spicer 1310 joints, and the occasional Spicer 1330.
Obtaining a positive ID on the joint isn't hard at all, just pull the joint, and measure it. If by chance you have stock U joints, you'll have to take a torch, and heat the caps up until all of the nylon melts out of the driveshaft and oozes out of the holes. Rather than using a retainer clip like the replacement joints do, GM uses an injected nylon retainer. Now that you've got the U joint out, you can measure it and see what it actually is. Here are the specs of the 4 above joints:
Saginaw S44: Cap diameter- 1.125", Lockup - Internal (clips inside the yoke) 2.556" Spicer 1310: Cap diameter - 1.063", Lockup - External (clips outside the yoke) 3.219" Spicer 1330: Cap diameter - 1.063", lockup - External 3.622" Spicer 1350: Cap diameter - 1.188", Lockup - External 3.622"
Now that you have determined the stock U joint, you can find which conversion joint you need:
Straight Size Joints: S44 Neapco PN: 2-3011 1310 Neapco PN: 1-0153 1330 Neapco PN: 2-4800 1350 Neapco PN: 2-0053
Conversion Joints: S44 to 1350 is Neapco PN 2-1153 1310 to 1350 is Neapco PN 3-3140 1330 to 1350 is Neapco PN 2-3050
If by chance you have any other combination, which would be an extremely rare case, you can look up the joints by size here: http://www.aawheel.com/SiteResources...oUniversal.pdf Dimensional listings start on page 260.
That's good info :)
Your link in that post is now dead GD.
But, here is some fantastic info that one might have to read a few times to gather and absorb it all. I may have posted this already, but here it is again since it's worth repeating info. Mega Good Stuff in this article with pics and detailed descriptions.
http://www.therangerstation.com/Magazine/summer2008/ujoints.htm
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Well, I ruined a nice $30 Spicer Life 3R (5-795X) U-joint with my impatience, so I'll have cutaways of it soon I imagine. :angry94:
sam s
