Johnathan25
- Sep 25, 2018
- South Carolina
- Johnathan
- C10
Hello everyone. I have a 1985 Chevy c10 that’s been running pretty rough here recently and I cannot for the life of me figure out why. When you try to crank it up you have to hold it for awhile before it fires up, and then as soon as it fires up it acts like it struggles to stay cranked, every now and again it won’t even crank and you have to wait awhile and then it will. Once it’s warmed up it idles pretty rough and jumps around, and when in gear it does it even more. Turning the air on makes it jump around way worse to the point where it almost wants to shut off. It doesn’t jump around while going up the road, but when you start off from a stop or slow down and start to pick up speed again it really feels like the engine is struggling to keep up and won’t pick up speed very quick, almost like it’s lost it’s power. Occasionally it’ll bog down so bad from a stop that it’ll almost stall out.
Here’s some info on my truck:
-the engine is completely stock minus a Holley carb that was added not too long ago and the emission stuff gone.
-just replaced spark plugs, wires, distributor cap, coil, and rotor.
-just replaced valve cover gaskets
-nothing else has been modified or tampered with.
If anyone has any idea on what could be wrong I’d really appreciate it!
