Thanks for the info. The plates don’t look the same, but I thought the rods did...FYI the rods are specific left to right. My truck was missing one of them when I purchased it, but I was able to get the one through Classic Parts. They used to stock the OEM parts, but they are no longer in their catalog. The catalog only lists years 78-91. Nothing about engines, transmissions or transfer cases.
I don't know if it's correct, but I installed the slotted ends of the rods on the flex plate cover side since the bolts and washer are much larger than those on the engine side.
You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attach
