Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
Very off topic here.....we have friends who are in their 70s and cant fork out the $100/hr shop rates anymore. They have an 06 Avalon that has a rhythmic knock in the left front wheel. It has zero play 9 to 3, but about 1/8"+ 12 to 6 (its defintely the source of the knock). Brake components are all newer and fine. I thought it would be a broken ball joint but the joint is solid, dry and boot is fine. My second guess was maybe a wheel bearing - still unsure.
So yesterday before carving the bird, I got a closer look at it - the entire outer CV joint where it enters the hub, moves when I flex it 12 to 6. Maybe its supposed to? The boots on the outer axle are also fine, but car has 200k so could just be shot. There was an identical situation posted like this on a Toyota board but no one answered the poster - 8 yrs ago.
Hoping one of you fellas that wrench for a living might have a BTDT idea about this. I have read that if it is an outer CV joint, its cheaper and easier to replace the entire outer axle assembly. It doesn't look difficult to fix but I just dont want to start tearing things apart and throwing parts (and money he doesn't have) at it.
Thanks in advance.
Thanks in advance.
