Towing a diesel 2500 Burb on a 17’ flatbed trailer
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Is it pretty safe to say that a j code 3/4 6.2 equipped 83 burb has a th400 if it’s an automatic?
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I saw that @bucket mentioned it, but you could load the burb backwards. It would put the longer overhang over the tounge, the narrower axle between the fenders, and the heavy engine bay a little closer to the trailer axles. I know you stated that you already had a rented trailer lined up, but just another tactic to consider.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I’d considered that, but didn’t want to risk not being able to get the tongue weight right and driving 300 miles back with an ill mannered trailer.
Auburn, Washington
Dually wheels with thin tires,nward to reduce track width
Good in theory but pretty sure the rim will hit the steering arm or spindle/ball joint whatever is closest behind the rotor.
abhhh, I forgot we were talking about a 2013ish suburban, my mind snapped to square/gmt400
I suppose even then , a spacer may be needed
Auburn, Washington
Huh? We are talking about a square burb. A dually rim has a greater offset than the width of the rim, so the brand/model of truck doesn’t really matter, it will just set the wheel so far in, that it’s bound to hit ****.
oh. i thought he meant newer burb because I saw a 6.2
Then, I wouldnt expect it to hit things with a narrow tire, these trucks had dually options
but ill admit idk if any of the work hes done would be in the way as opposed to stock
bluex
Spartanburg SC
C15
It'll hit the caliper first. The way they neck down inside it won't clear the brakes without the spacer on the rotor. If you pulled the calipers then it would hit the other stuff too....
Seibelc1077
