Toad455
- Aug 3, 2023
- North Texas
- Kevin
- C10
Hello, I'm not sure if I should have posted this in the paint and body section but since it's suspension I figured I'd start here. I'm fixing to sand blast and paint my frame for my 78 2wd. My question is I'm not sure if I should remove the lower front frame cross piece that's under the engine, that the lower control arm u bolts attach to. I believe it will clean up and paint easier if apart, there's only three bolts on each side that hold it in, BUT it also seems like it may be a pain and maybe I should just leave it alone since it's in the correct position. Would any of you remove it just to paint? Thanks.
