To remove or not to paint frame?
Toad455
North Texas
Kevin
Hello, I'm not sure if I should have posted this in the paint and body section but since it's suspension I figured I'd start here. I'm fixing to sand blast and paint my frame for my 78 2wd. My question is I'm not sure if I should remove the lower front frame cross piece that's under the engine, that the lower control arm u bolts attach to. I believe it will clean up and paint easier if apart, there's only three bolts on each side that hold it in, BUT it also seems like it may be a pain and maybe I should just leave it alone since it's in the correct position. Would any of you remove it just to paint? Thanks.
They're not bolts, they're rivets and they're a PITA to remove. Depends on how far you're going with the build. Cool little cruiser/driver or super nice show truck?
Fri00
PA
Shaun
N/A
are you referring to the entire k member? If so that’s a pretty straightforward unbolt. Anything riveted I would say it’s not worth it unless they’re damaged or there’s rot.
legopnuematic
Licensed Junk Dealer
MO
Spencer
On my 79, I had the frame blasted as a unit, as having it be a roller was important at the time, then I disassembled it, cleaned the remaining areas with a purple 3m wheel, then painted and reassembled.
If you look at my 79 thread in my signature, starting at post 495 shows that process.
Toad455
North Texas
Kevin
This one has three bolts on each side. The support underneath the engine. I'm building it as show and light driving but no mirrors on the floor or anything like that. Just local shows.
Toad455
North Texas
Kevin
Yes, I believe it's the k member, no rivets that I can see.
Toad455
North Texas
Kevin
Nice, thank you. I'll check out your thread. That cross member looks heavy.
legopnuematic
MO
Spencer
It’s not too bad, maybe 50lbs give or take?
Toad455
North Texas
Kevin
After seeing your pics it's coming out today,ha. May as well since I can blast it at home like I did the cab and all the other parts. If I don't do it I'll regret it later even if you can't tell whether or not it's been out, but I'll know.
Toad455
North Texas
Kevin
Lego, on your second pic from the top, what are those two plates on the floor? I see them bolted on in your top pic. Are those just for lifting? Thanks.
legopnuematic
MO
Spencer
Brackets for a tow bar I made when I flat towed the truck once.
Toad455
North Texas
Kevin
Oh ok, thanks. That's cool idea.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
I did mine myself, but in retrospect sand blasting is way faster, I only un bolted what would unbolt. My motor mt rivets were a little loose so I heated then up and beat them with a big hammer while holding a sludge hammer on the other side, so check for loose rivies.
jstewart7501
