74 Shortbed
- Aug 12, 2013
If the plate is seizing up it won't move, need to take the vacuum can off and put vacuum to it and see it the arm moves. Just replacing the cap and rotor is not rebuilding the distributor, it needs to be taken completely apart and cleaned and replace bushings/shaft if needed and new lubricant on the top and make sure everything moves freely..
