hatzie
- Dec 6, 2011
- NH
- David
- k20
Alright, so I finally got around to finding TDC and found that the original mark was off by 26.5°! I'm glad someone mentioned the rubber dampener allowing the outer cast ring to move. I found this using the piston stop. The orange dot is the original mark and the 2 small silver lines are where the piston hit the tool on either side of TDC. Then the long mark is splitting the two. I estimate 13° between each mark for a 7" harmonic balancer.You must be registered for see images attach
Sent from my SM-G935V using Tapatalk
Time to replace the balancer. A moving harmonic ring will not stay in the same place and it will eventually break your crankshaft. The 6.2 6.5L Diesels are very very bad about that. I used fluidampers as replacements on all my diesels.
Be sure to get the right one for your engine and timing tab.
