RecklessWOT
- Feb 20, 2015
- New Hampshire
- Kevin
- V10 Suburban Silverado
- 350 TBI
So the time has finally come, the 350 in my burb is getting yanked (when I get around to it).
It's had a bit of a stumble for the better part of a year now that I could never quite figure out, performance was down and oil consumption was up but I wasn't too concerned, just figured it's a tired old 350. Towards the end of the summer when it was real hot out the truck began running hotter than I'd like to see, I assumed it was from my old calcified radiator which I cleaned the best I could. Then it clearly overheated pretty bad one day despite not showing on the gauge. The same day on the way home the radiator started leaking so after letting it sit a couple months I recently sprang for a nice new aluminum 4 core radiator, figured that should fix the temp problems. I haven't been driving it much lately but I've had weird temp fluctuations ever since, at first I just thought it was running cool because of the huge radiator but lately have noticed it jumping back and forth between like 150 and 200 so I assumed it was just trapped air in the system. Yesterday I went out to bleed out the air and lo and behold I'm getting lots of exhaust in the cooling system.
So best case scenario nothing is cracked and it's just a head gasket, but I'd still want to swap the heads out while I've got it apart, that thing is a dog. Then I think it's a 350 with around 170k on it that burns oil, if I'm gonna throw heads at it I should rebuild it. Then if I'm gonna rebuild it, I might as well do a cam. And then I think to myself, well if I'm gonna go ahead and do all that why don't I just buy a ******* crate engine and be done with it?
Long story short, it's getting a new engine. There are so many options out there I'm not sure which is best. Whenever I search online there are so many different choices it kind of turns me off and think "I'll deal with that later". I'm keeping it a 350, I don't want to mess around with an LS swap or anything, want to keep this simple- It's winter and I currently do not have a garage. Just a regular 350 crate engine, ideally something with a little more power than the current setup. I always wanted to do a 454 but I would need a different transmission and axles and all that fun stuff, at this point I just want it back on the road and reliable. Even though the TBI sucks, I do like the convenience of fuel injection and would like to keep it if possible. What do you guys think, any ideas? Positive (or negative) experiences with specific engines you've bought?
