Throttle Body Fuel Injection Conversion
cooter55
Placitas, New Mexico...not really New...not really
Jack
C20, R10
454FI, 350
I have a complete Carb to TBI fuel injection conversion set up for sale. It includes a GM 2" throttle body, manifold adapter plate, an Airaid spacer, labeled wiring harness, 1227747 ECM, all sensors, wide band O2 sensor with welding bung, fuel pump and filter. You will need a return fuel line to the tank, weld in the bung, and supply a standard air cleaner. This was used on our test motor and can be set up for a small block or big block, depending on the chip installed.
Complete kit as described.........$500.00 plus shipping
Questions....call me.....505-259-6870 Jack
yeti_87
