Thread sealant on header bolts?
Truck82
Alderton
Christopher
Just wanted to know what y’all do when installing headers.
Thread sealant on bolts or not?
I’ve heard both yes and know and want your opinion and experience.
Thank you all in advance!
Truck82
Alderton
Christopher
seal 'em from what?
Ive put grease or anti seize on 'em to keep from rusting stuck and breakin' off when removal time comes
I thought they might be connected with an oil passage? Maybe I’m stupid but a bolt on the back side of my manifold is leaking oil. I’m swapping the stock manifolds out for long tube headers and didn’t want any more leaks
Bennyt
Surprise
Ben
Always anti-seize on the bolts.
Ways to keep them tight:
Frequent retorque
Bolts that have cam locks
Washers with fold over tabs
Drill the bolt heads and use lock wire
Do not use lock washers!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Valve cover leak or someone ram rodded too long of a bolt in possibly, but I doubt that would hit oil.
Truck82
Alderton
Christopher
I just replaced the valve covers and gasket so I think I can rule that one out. Could still be possible. It’s happened to me before.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Shouldn't be intake or oil press sending unit. Those usually run on the bottom surface of the head. Either residual or valve cover.
koolbrezz
