The squeaking is getting on my last nerves
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
What’s up guys!!!
…so recently I lowered my front end drop spindles, drop springs, drop shocks and I’ve also changed out all of my front end parts, bushings, control arms, ball joints, bump stops you name it…but now I have this squeaking sounds on the right and left as the truck drives. I’ve lubed every grease fitting possible and it’s still squeaking…. any remedies to this situation ????
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Crank your music up haha
Do you have a front sway bar?
Normmus
Saskatchewan
Norm
Did you use urethane bushings or rubber bushings? I've heard that the urethane ones can be loud if not sufficiently greased on installation.
yes i have a sway bar
It could be that the bushings are not happy in their new position at a lower ride height. Or if they are new, poly bushings tend to squeak without grease.
Camar068
10 yrs Air Force
Was gonna say, I hope you didn't use all poly bushings...
yeh I hate that they make them red so they look cool and all lol. Needless to say, that's what's on my truck. Live n learn.
Helped a buddy in college do all the bushings in his foxbody in poly. After 6 months, could here that MF'r coming from across town. Never again have I touched a poly bushing
Scott91370
Burleson, Tx
Scott
Sierra1500
Did you tighten everything after the truck was down on the ground with the full weight of the truck?
Also, grease joints and bushings.
ANGEL1688
