fullbore
- Oct 26, 2016
- Washington
- Mike
- k20
Hello all!!
Hope someone has had this same problem. I have a th400 that as you put it into drive ans start to move when it starts to upshift to 2nd bounces right back into 1st. Then if I hold the peddle there it will go back and fourth untill i stomp on it or let off. The rpm climbs hi then shifts into 2nd. i believe with the governor. Then has a real big problem shifting into 3rd. Sometimes it does and sometimes not. When it does get into all the gears 1-3rd there isnt any slipping .
I have changed out the modulator and cleaned the " Hard " line from the intake. Also removed the governor and checked for proper valve movement and inspected the gear.
Anyone have any other ideas?
Thank you in advance
