Swearbody
- Nov 4, 2018
- Birmingham AL
- Jeff
- C1500
- 355 sbc
So ive never had a 700r4 before this truck and do not know its characteristics . That 1-2 shift is something to get used to for sure. The trans feels fine as far as I can tell but what do I KNow.....I dont know what its supposed to feel like.
I cant really feel the 3-4 shift at all but can feel it downshift from od occasionally so I know its happening. Mind you its possible I havent gotten in to the throttle long enough to "feel" a 3-4 shift. TV cable has been adjusted and it downshifts fairly often(when it should it seems) so i assume its matching pressures properly.
However I have quite a few suspect looking wires under the hood and the vacuum lines dont look any better so I cant be sure the lockup is even connected. Ive seen posts claiming the lockup is tied into the egr system somehow but could be misreading that. I have a edelbrock carb and the egr has been removed along with anything pertaining to the quadrajet and oe air cleaner/filter housing.
SO my question is: How do you know if lockup is happening. What are the characteristics of one where the lockup is malfunctioning. What is necessary for it under the hood.
Thanks ALL!!! I promise I confused myself by looking for the info elsewhere,LOL
