Tbi runs strange
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I checked the plug wires. All look good. No holes in them. The fuse that blew was ecm 1
Well if you need an ECM let me know. I have the one from the 87 which worked and one from the 89 which is an AC Delco reman.
87silveradok20
Ohio
Levi
Silverado k20
I got the truck running again. It ended up being the plug for my egr fell down and was laying on the exhaust manifold causing the egr plug to short out. I still am having the problem with the truck stumbling tho. I got a fuel filter and am gonna give that a shot
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
That’s interesting. Glad it ended up being something non-invasive. Keep us posted.
87silveradok20
Ohio
Levi
Silverado k20
Fuel filter wasn’t the problem took it for a drive and it’s still not running right. It sounds like it might be beck firing thru the intake.
Billy
Dalton Ga
Billy
I had a similar problem and it was the ecm ground . It's grounded with the cts
mikedgarage
Asheville NC
V20
If you use an ‘87 ECM in make sure you use the ‘87 knock sensor. They changed it fo’89 and up.
87silveradok20
Ohio
Levi
Silverado k20
The ecm number was the same on both trucks. Do I still need to switch the knock sensor
mikedgarage
Asheville NC
V20
You may not need to if the Part numbers are the same. It could be a late '87 ECM, after the change.
Dan Brown
Katy, Texas
355 (.030 over 350)
Check the Idle Air Control motor. Sometimes they'll act up and not set a code. Take it out a clean the plunger and passages and see if that helps.
DBurns007
Houston/Seattle
Danny
5.7 TBI
Hi..
I would take a really close look at your throttle body gasket and ignition..Primary and secondary. Start the truck, let it warm up and bump a little carb spray at the throttle body gasket... listening for idle up witch would indicate a vacuum leak. Also would explain misfire and erratic idle... remember, carb spay is flammable. So.. actually. Disregard. I would say check all of your secondary ignition. Plugs, wires, cap and rotor..
And just change the throttle body gasket. I’ve seen the throttle body gasket cause your symptoms many times.
Have a look at it..
Also.. check vac. Leaks at the blocked off EGR.
Shoot us a pic of the engine if you can..
Assuming you still have the truck?
Tjreid
