TBI pods are leaking!
ozark plateau
dennis
k5
I lost an injector and the pickup coil partially whenever my ICM blew and tried to go the cheaper route. It was still a new injector, Standard Motor Products PN# TJ7, but not at the Delco premium price point. Big mistake, the design is garbage. The nozzle sits up inside a conical recess of the injector rather than at the tip like the OEM ones, the screen is integral to the body, not a little slip on neck like the original, and it sprays outward, down, and splashes up with little to no control. RockAuto shows TJ7 as a reman so maybe they quit making/distributing the new ones, but Amazon still shows the same PN as new replacement with a picture of what I got. Either way, I’m not paying $80 per unit again for the privilege to find out. I was lucky enough to find a correct Delco replacement dated 2001 for the same price, and it worked like a charm.
thanks for that info! curious, if they are reman, what was the original manufacturer and fitment? i looked at ebay so i could see more pics, and they are definitely different. thanks again, you saved lots of folks lots of $$$$
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
I don't think I'd trust ATF to install those injectors. I'd use motor oil or grease to do it. They need to stay slippery until the bolts are tightened. I have used motor oil successfully, but I'd probably go with grease if I had to go back in there as many times as you've had to.
Joe
The picture on RockAuto leads me to assume they’re remanufacturing whoever made them originally, I’m guessing Rochester Product Division, Delphi, or both. That new production one fits in the injector housing perfectly, the external dimensions are identical to the OE unit, and it doesn’t leak out the top, just everywhere else in my experience.
The remans might be okay knowing that TBI injectors are really only susceptible to coil/solenoid failure and getting dirty, but I’d be very leery of any remanufactured injector without putting lots of miles on one. Even then, who would risk a breakdown when you can get a good new one for not a whole lot more.
Joe
Dielectric grease works well.
jlyon1006
