Leaking Metal Fuel Line??
legopnuematic
Licensed Junk Dealer
MO
Spencer
Lots O' options. If only a small section is bad just cut, flare, use a union to join a new piece in, check inline tube, or summit, jegs for full replacements.
It should not make a difference between single or dual tanks, it's soft lines to the selector valve.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I think your helper has been waiting a very long time, appears to be well beyond rigor mortis.
Ronno6
South Mississippi
Ron
I did the same...shipping to me is $31.00 for a $49.00 part.........
Summit does not have, AFAIK
Ronno6
South Mississippi
Ron
Inline tube was same price shipped as LMC...
Stainless would be a bit more.
Not sure if 6' would do it......
legopnuematic
MO
Spencer
Another option is getting a roll of Nicopp tubing, 3/8". I've never used it myself but it bends and flares easy.
Do note that the factory fuel line from tank (or selector valve) to fuel pump runs underneath the passenger side motor mount plate, if I'm remembering right there is a clamp under there as well that holds it to the crossmember.
Ronno6
South Mississippi
Ron
Good tip! Thanks.....
Ronno6
South Mississippi
Ron
Yup. you remember correctly...unfortunately.
So, how do I extract that bolt without removing the mount & plate???
Also, there is a spot where all 3 hardlines rub up against a header tube; NOT good.....
Sigh, gonna be busy........
Ronno6
South Mississippi
Ron
If it was a hole in the feed line, you wouldn't be able to pump any gas... it would just be sucking air. It is most likely either the weep hole in the bottom of the pump or a leak in the return line. There are two rubber lines from the frame rail to the pump and two more from the metal line to the switching valve. I'd start there.
The supply line is the only active one in the system currently.
The vent line is not connected, and the return line is connected to the
fuel HP pump sump for the EFI I am installing.
Ronno6
South Mississippi
Ron
Dunno why some whiz-bang engineer designed the routing of the metal lines under the motor mount plate.....they come way off the frame rail, but do not need to.... so far that they hit a header pipe... now I gotta replace 1 and re-bend (hopefully) the other 2... there is another hard line, probably the rear brake line, that hugs the frame much more closely.... I will need to duplicate that line with the fuel lines. But, it looks like the mount and plate need to be removed and the engine jacked up a tad. I hope I don't have to pull the header off.
Ronno6
South Mississippi
Ron
The fuel line is out...no easy feat.
I did have to remove the motor mount frame plate and jack the motor
over to the driver's side a bit.
A couple of answers"
Yes, the line has a hole in it. Definitely the source of the leak.
No, 6' would not be long enough to replicate the factory line.
I will look to modify some of the bends to shorten the length needed.
Now, to decide how to proceed.
CT210
Ca.
Try Inline Tube website, they have most everything in factory style pre bent lines.
Ronno6
South Mississippi
Ron
See Reply #19 above...
Thanks.
Steel fuel line tubing ordered from The Stop Shop thru Amazon...
Ronno6
South Mississippi
Ron
Cancelled the Amazon order from the first vendor cuz they couldn't seem to ship...
Ordered from a second source....they haven't shipped yet, either.
I NEED THIS STUFF..................
I've always walked into my local parts stores and picked up steel line. No waiting. And the engineer who routed the fuel lines did them that way because it was most efficient for assembling the vehicle and cost effective. It wasn't done with the intention the truck would survive 40+ years and develop a leak and need a different fuel line routing for non original equipment.
Ronno6
South Mississippi
Ron
Local parts stores did not have the fuel line longer than 6'. That left me about 1' short.
My statement about the engineer is in regard to the placement of a retaining clip underneath the motor mount frame plate.
This requires removal of the fuel pump and mounting plate, which can only be removed after pulling the motor mount thru bole and
jacking the motor over to the driver's side so that the plate and lower mount can be extracted.
I guess the engineers never anticipated having to replace the hard line.
The routing also hugs the frame until it reaches the MM plate, at which time it comes off the frame rail so far that the fuel lines contact the header pipe. I know headers were not standard equipment, but I see no reason to deflect that far away from the frame at that point, especially as it positions the routing clip in a location that cannot be accessed without removing the plate..
luis1jr
