- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
Heres a 14bff for yea. In the back of my 76 C20 131.5" WB. 8200lb GVW
Did the blazer fuel tank mod, 31 gal,
That is really for Rusty, lol
What did you end up doing for the front crossmember for the blazer tank? I have a 31 gallon tank I'm putting in and I got both front and rear crossmembers with the tank. The part of the frame that the front crossmember bolts to on the blazer frame must be flat though and on my K25 frame it is raised up quite a bit. I'm thinking I might just cut a slot in the brackets for the frame to slide through and then just have spacers on the top and bottom of the bracket where the bolts will go through to the frame....
