Stock Temp and Oil pressure gauge.
84 Shorty
Grovetown, GA
Andrew
Im wanting to get my stock gauges working and get rid of the aftermarket gauges. How are these wired, there’s nothing running to them.
84 Shorty
Grovetown, GA
Andrew
Thanks, should be able to track down the wires coming off the main harness that feeds the printed circuit and tap into them.
85 CA SIERRA 1500
So. Cal
TRACEY
SIERRA CLASSIC
Hi Andrew, might not be a wiring problem but rather a break in the PCB, especially if the gauge cluster has been has been taken out from time to time to do things like replace bulbs and what not. Could also be that the connector needs to be cleaned, are you sure that the sending units are are connected?
All the best,
Tracey>>>>>>>>>>>>>>>>>>>>>>>>>.
84 Shorty
Grovetown, GA
Andrew
I got it working, track down the cut wires at the firewall and swapped the units out. Thanks for the help fellas
350 w/203
78silverado
