Steering gear support
highdesertrange
kalifornia
mike
k30
I run both if my frame is cracked or not. highdesertranger
johnnie59
usa
johnnie
silverado
I don't know if there is a weld on repair for the rwd. I know that the bolt on braces are available for 2 and 4wd.
My ? Is is my r10 frame the same as k10,k20?
Bennyt
Surprise
Ben
For 2wd frames, I'd just weld the crack up and use both the Ridetech braces and the ORD or Autofab braces. The ridetech triangulates the entire front end and supports the rear steering box bolts while the others reinforce the front two. I'd also drill out the rivets on the front crossmember and install bolts. If you do all this, you should never have a problem again.
F-64
nyc
mike
R10 lwb
5.7 tbi stock
R10. We welded a K-brace across to the other frame rail using 1" square tube. It helps prevent the twisting that cracks the frame.
Squarebuddy
