- Sep 29, 2010
- Green Bastard Parts Unknown
- Jay
- pontiac aztek
I would check the "rag joint" on the lower steering shaft.
all ball joints have been replaced, I was told when I got my truck aligned that everything looked fine...
And I already installed the new gear box and test drove it. Like I said, its much better but I wish it was more responsive when i turn the steering.
Older design isn't like todays cars and trucks, also, you're reffering to an off road 4x4 steering system, not a sports car. Not sure, maybe you're expecting to much??? If in doubt, have it checked out again,and make sure everything is tight in your steering gear.
It's right at the steering box. And there is another joint that wears out up at the other end of the shaft.Which is the ragjoint and what does it look like?
img upload
Nope, Nope, Nope. Will the salvage yard take that 2wd drive unit back? I'd hate to see someone wasted $45. ORRR, just hold onto the 2wd box for a crossover steering conversion someday if a big lift kit is in the future plans cuz the only time you need a 2wd streering box on a 4x4 is if you're doing crossover steering.
