Steering and suspension rebuild 84' K10
itscaleb
Tinker AFB, Oklahoma
Caleb
In about 9 months i have to move about 2k miles and I'm worried enough about my steering and suspension that I'm going to have my mechanic friend do a complete rebuild on them.
I have 2 questions.
First, is there a complete kit for both?
Second, what would the difference between a suspension rebuild and a 2" suspension lift kit?
Everything I've tried to look up always comes up with results for individual kits and when I look up the suspension rebuild vs lift kit I only get results for suspension lift vs frame lift.
This is the first time I've attempted this so any and all assistance/advice would be greatly appreciated.
Thank you in advance.
Camar068
Kentucky
10 yrs Air Force
Is everything tight now? Do you have any play (more than expected)? Ball joints, tie rods and bearings aren't that expensive. RockAuto will cut your price in half easily compared to local stores....and thats the same moog part #'s from both. Don't forget we get 5% off here. You've got time, order here an there if need be.
itscaleb
Caleb
I've got a 1/4 turn play in the steering (about 1/8 turn in each direction) and I hear a rattle in the front left whenever I am moving. Also, the truck sat in mud up to the door frame for about 3 months before I bought it from the previous owner so I don't trust the parts that were below. I already replaced the front brakes. Still need to rebuild/replace the rear brakes too.
Camar068
Kentucky
10 yrs Air Force
I'd replace the front axle u-joints while the balljoints are being replaced. Sounds like it would be a good idea to pull the cover and change fluid on the front/rear axle.
jbahena95
