Rusty Shackleford
- Mar 29, 2021
- Vancouver, BC
- Tony
- R20
- 5.7 L
Looking for some things I could look into which might solve this problem I am having. Have searched and found some threads but they sound a bit different than my situation. Previously, the truck would start with no problem but would run rough at low speed. If I drove it to the end of the block then shut it off for about 15 to 30 seconds, it would fire up and run fine. This happened for a while. Now it will start up right away but go into rough idle and stall. Upon re-start, it won't fire unless I press the gas pedal to the floor. Higher idle speed is smooth. Check engine light came on and i found a 33 code (MAP Sensor). Replaced the sensor, air filter, and gas filter. Same problem as before. I took the air cleaner lid off and (engine off) a white vapour was coming out of the TBI from below the injector (passenger side) and a smell of gas. When I get it started it runs rough before it stalls. I will pull the plugs to see if there's something there. Any suggestions appreciated. Thanks, in advance.
