The shackles are off a chevy 1 ton crewcab and i measured and from bolt to bolt they are 6 inches.
Your tape measure is broken, or it's not A stock shackle.
the 2 wheel drive bracket is shorter and does not hang as low as a 4x4 mount
if you want more lift cut your front hangers off and space them down 2' or so with a peice of square tube then redrill the mounting holes
then use 2 wheel drive brackets on the rear for the shackle flip
