smog pump??? how would I find out if my truck had one?
charlesg
wisconsin
charles
k3500
anyway to find out?? 91 r3500 454
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Why, do you plan on replacing it?
charlesg
wisconsin
charles
k3500
no, if it was removed do I have to reprogram the ecu for it not being there?
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
How does it run without it?
charlesg
wisconsin
charles
k3500
kinda runs like ****, that is what got me thinking about a chip was talking to a guy that burns them and he asked about that. Said there is a part of the program that runs the air valve for the pump. The truck falls on its face when getting on it.
Craig 85
Nashville, TN
454/TH-400/NP205
Napa lists this smog pump for a 1991 R3500 with a 454. NAP 51278. I then found some info on motorhome P30 chassis with a 454. On label it says 1990-1994 the smog pump was eliminated. In 1993, I ordered a C2500 Suburban with a 454 and I don't recall a pump on that one, even in California. The cat was just IFO the rear axle though.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
I think you need to get a reflashed ECM.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Is the underhood sticker still there? Was most likely found on the air cleaner housing.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Stand by
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
steve.maneu eBay seller.
No tuning needed to run without the smog pump. I've got plenty of experience removing them and all still ran well.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Is there a distributor on that motor?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yeah, nothing should need to be done to it. At least regarding the smog pump. How did you plug the holes, and does it have any exhaust leaks right there at the manifolds that could be confusing the O2 sensor? I think it’s something else. Any check engine lights?
do4410
