AyWoSch Motors
The Parts Guy
- Nov 6, 2020
- New Mexico
- Ayden
- K1500 Sierra
- 350ci V8
Okay, i know its not a squarebody, but its not far off, and i involves alot of squarebody donor parts.
Have a 1992 GMC Suburban K1500, with a TBI 350, and a 700r4.
After 300k plus miles, the 700 is finally slipping, never been real pleased with it anyway, so want to manual swap it..
Im also working out doing a nv3500 swap into my 86. So that leaves me with a spare sm465 with nothing wrong with it. No the burb has a real high rear gear like 3:08 or somthing, so a non OD 4 speed will be fine.
Measured transmissions, the 700r4 amd the SM465 also are the same case lenght, same mount lenght, same bell housing, same T-case pattern.
Ive collected parts. I have a clutch pedal amd brake pedal assembly out of a 91 pickup. I have a clutch master cyl, line, slave cylinder. I have a flywheel off the 91 pickup. Also have a trans tunnel extension and cutout, shiftboot and trim peice for inside. I don't care about the column being auto.
Now my big questions are these...
1: is the output shaft spline count the same from a 86 sm465 to a 92 NP241 that was pairer with a 700?
2: will a squarebody bell housing with a external slave cyl on the drives side fit a 92 with the drive shaft on the drivers side, or will they collide.
3: will the speedometer still work? I think the speedo plugs in in the transfer, but not sure...
4: will a clutch set from a squarebody fit the 91 truck flywheel and match the trans? (Because the one in the 86 is nearly new)
And 5: will any of the TBI electronics care or will the computer have a panic attack not getting a signal from the transmission?
Any help is appreciated, thank you.
