Sm465 or other options
777mech
Stanwood, WA
Trying to decide which trasmission to use when I put my truck back together. It's a 2wd shortbox that came with a sm465 4 speed. The few years I drove it the rear end was geared at 3.73 and it seemed alittle low for freeway speeds. Do any of you have a 465 in your 2wd truck and drive it alot on the highway? If so what are you running for rearend gearing? People keep suggesting to put an auto in it but I have always perferred manual over auto. My intentions for the truck are to lower It and mainly use it for cruising around and going on the occasional long trip down the freeway. Should I stick with the 465 or is it silly to use it for my street truck that never go off-road or tow anything super heavy? The motor I use will most likely be a 383
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
Depending on budget, there are some options. NV3500 or even a tremic 6 speed. Both will have overdrive.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Since you’re just cruising it, you could just change diff gearing.
CookieSoup
Seattle area
Suburban
there is a chevy 2wd NV4500 on offer up down in maple valley if you wanted overdrive
eskimomann209
Modesto
Marcus
All sound advice
Nv3500 if you plan on keeping engine stock
Nv4500 if you plan on ls swap or an engine build
You can even work the nv5600 these days
78silverado
