Should of stayed in bed
Boltrunner
Odin mn
Shane
V20
So trying to get wood cut today for the storm rolling through on Friday my saw stopped working. But thats minor i suppose. My problem is that my lovely blue bomb has developed an intermittent no start. Its done it a few times before to me. Usually cycling the key gets it going. Yesterday it happened after it sat for a few hours while i was at a fire department training. Cycled they key about 10 times and she fired up. Engine was cold. Today it happened twice. The engine was warm. Today i cycled the key a few times again and no go. Poured some fuel into the throttle body and it took a few times. My fuel filter is only a couple months old. Every other time my fuel filter clogs i get issues while driving. Never a no start. What could be the issue? As im sure some of you know my diagnostic skills are lacking so im turning to my truck bros for help.thanks
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Possibly your fuel pump shitting the bed.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Is it cranking, but not firing? Or are you turning the ignition with nothing happening?
78C10BigTen
pennsylvannia
C10 BIG TEN
I have that issue with mine, it wont crank, hit the key and it gives one click and thats it. Its completely random too, if i keep hitting the key itll eventually crank.
Boltrunner
Odin mn
Shane
V20
Oh no she cranks like a champ.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Get someone to crank it over and feel and listen for the fuel pump. If the pump is weak and the voltage is down it may just not want to work. If you have an Amp clamp check for excessive current draw on the fuel pump wiring. That will tell you is tailing.
Boltrunner
Odin mn
Shane
V20
I hear the pump prime but i know that dosent mean its working fully. I have a clamp on multi meter that should have the amps function correct?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
If it has a clamp yes.
Camar068
10 yrs Air Force
You could get a remote start switch to hook between the solenoid on the starter (signal post not starter power) and the battery. After the autozone model lasting only 10 turn overs, next time I'll just run a wire down there and short it to the positive terminal on the battery (key off). Just bump it and see if it messes up. If it doesn't, then it's likely your ignition switch. If it does, it's from starter to battery or ground.
Pull ignition power from the distributor so it won't start.
Boltrunner
Odin mn
Shane
V20
The starter works perfectly. Motor turns strong. Im gonna test the fuel pump wires for amperage when i get home. Had a buddy crank it over while i watched under the hood. My fan clutch is a little worn but thats about it under there.
What should the amps be for the pump? And i should test closest to the pump correct.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I can’t answer that with any kind of certainty. I can only say that 15+ amps would raise a flag with me. @1987 GMC Jimmy or @chengny may know off the top of their heads though.
Boltrunner
Odin mn
Shane
V20
I guess on a better note i am having another baby. Time to get snipped hahaha. If my math is right (and i have 10 fingers so should be good haha) shes due around Christmas. Hopefully the money situation improves soon so i can keep my blue bomb
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Congrats???? Lol I had it done at 30. Frozen peas are your friend, but what do I know I was out putting a trampoline together right afterwards. Lol
Boltrunner
Odin mn
Shane
V20
Haha well this will make number 3 for us. Im 34 and shes 29. Our boy is 7 and our girl is 6. Kinda happy that we have some space between on this one lol. But no more.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Lol
rljohnson013
