77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
I'm not quite sure what length the stock shock is. ORD recommends a 10" shock (16" collapsed, 26" extended) for the rear with a 2" lift.
It depends on your springs. If you have the extra HD rear springs then they won't move much and I suppose a stock shock might fit- but you run the risk of over extending the shock and breaking it.
What are you using for a lift in the rear? A 2" block? Typically a block that small doesn't cause any issues. Larger blocks (4", 6") can cause axle wrap/hop. Basically if your rear tires spin the axle bounces up and down. An easy way to break stuff. The extra leverage from the block can twist the axle a bit then it snaps back.
I was having some issues with my 3" block and old very worn leaf springs. I went with the 2.5" shackle flip and new stock springs. But since my old springs were sagging so bad it raised a lot more than 2.5"
Basically the shackle flip moves the rear of the leaf spring down to provide lift. In the case of the 2.5" shackle flip it moves the rear eye of the springs down 5". The ride will improve even on your stock springs because they are now allowed to flex and move around a bit.
Installing means drilling, grinding, or chiseling off 6 rivets per side then bolting up the new bracket. You can re-use the stock shackle but their HD shackles are very nice.
