77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
So I got new front springs today (ORD custom springs) and figured it wouldn't be too hard to get the Tuff Country HD front springs off since I only put them on about 4 years ago, and that included the Bilstein 5125 shocks.
The lower shock mount, the nut came right off. Great! Then realized I can't get the bolt out. The bolt freely spins. The rubber/urethane bushing doesn't spin. Grabbed a small sledgehammer and gave the bolt some good hits with the nut back on to protect the threads. Bolt still stuck. All that did was bend the one shock mount tab out a bit. I can look down in there a bit and now see that the $#@!#@ metal bushing must be rusted/siezed to the bolt itself. The metal bushing spins with the bolt. The metal bushing is larger than the shock mount tab holes...
The shocks are still good- they are just too short for the new springs. How the hell can I remove them without damaging the shock? Only thing I can come up with is grind off the head of the bolt and grind off the nut side flush. Then pry, spread the shock mount apart and hope it doesn't crack. If I get it wide enough maybe I can pry out the stupid shock...
Or?
Now the next part- to mount the new Bilstein shocks. I have no shock hardware. And obviously what I used last time sucks (not even sure where they came from). Just buy stainless bolts, nuts, and washers and use them?
Anyway- luckily I was able to remove the top of the shock at least. I had to do that as the new springs have so much arch I had to drop the axle way down to get it to fit. The new springs make the axle droop way down with just the weight of the axle... which is 1.5" inches lower than my old shocks fully extended. The new spring pack is 59 lbs. Tweaked my back wrestling it into place. So I only got the passenger side done.
Or?
