usar17
- May 3, 2012
- PA
- Shawn
- K20 Silverado
- TBI350/700r4/NP208
Well as some of you know my 85 k10 hasn't been the easiest rebuild. Especially with not having access to a good amount of tools.
History:
has a 305 in it. Rings are most likely shot. No crankcase ventilation, as in i have positive pressure at the breather instead of negative. good vacuum at PCV valve. Took breather off that goes to air filter bc it was slowly saturating the filter with splash up. replaced it with a push in breather filter.
pulled the valve covers off to clean them up and clean out the baffles and check for clogged vent holes in the heads. First re-install attempt was with rubber gasket, valve covers leaked. second attempt was cork. passenger side still leaked. third attempt was cork and RTV. worked.
turned my attention to maybe making this engine last a little longer till i could save up my money to purchase and put in a 350 my friend has. added a can of Restore engine restorer and lubricant. can said it helps reduce blow by and i thought that may help gain vacuum in the crankcase. Ran great for a little bit, more throttle response, seem to be working good.
Restore
http://www.autozone.com/autozone/accessories/Restore-19-oz-8-cyl-engine-restorer-and-lubricant/_/N-4b63?itemIdentifier=521229_0_0_
Preset:
she's leaking oil bad all over the passenger side valve covers. it's not a bad seal because its coming up and out of the filler neck too. oil pressure gauge isn't reading any higher then normal, roughly 35-40. but i have a major oil evacuation happening. Driving it just causes a ton of bluish grey smoke from the engine compartment. I can see it dropping down at idle and burning off the exhaust manifold. The frame, front driveshaft, starter, and transmission are covered in oil now.
any thoughts? or is she done?
History:
Restore
Preset:
