- Feb 24, 2020
- Auburn, Georgia
- Zach
- Sierra 1500
So did it make it worse or no change?
I'm curious.. I've crawled around a fair amount of these trucks and have never seen a cardan joint on a rear driveshaft.. i've seen two piece driveshafts and some odditites but never a setup like that. All the time on front driveshafts but never the rear. Was it year specific or application specific? I'd be curious about the phasing of the driveshaft and balance as well. Is there any noticeable play in that joint if you try to move it up and down or side to side? Having an extra joint just seems like a place to cause problems. I'd think i'd have that removed and a proper length driveshaft made. Or explain it to me, because i'd like to understand the reason or the need. i'm genuinely curious!
It's common on lifted trucks. I believe dodge used them in the past as well on non-lifted trucks. I could be wrong, that's what I was told. The benefit is that it runs smoother because the two joints cancel each other out. This also adds greatly to the life of the joints. In my case it's probably overkill and not needed. Since I was starting from scratch it wasn't much more $$$ to use a carden. For instance, I paid $550 for the entire shaft. The other "perceived" benefit is it's length doesn't count towards the shaft length. Since my setup (NV4500/205) is relatively short for a long wheelbase truck that was also a "perceived" benefit. To your point, yes, I can feel a minute amount of play in the joint and that's what caused me to notice the excessive endplay in the output shaft. However, I now believe the play in the output is normal and acceptable for this t-case. But, I think combined with this driveline it's a bad combination. Most lifted trucks that NEED this probably don't spend time on the highway at 70mph. For mall crawlers and offoad, you would never notice it. In my case with 4:56 gears that driveline is seriously humming on the freeway. I'm sure any imbalance will make itself known. Or--I'm completely full of S**T and grasping for straws.I'm curious.. I've crawled around a fair amount of these trucks and have never seen a cardan joint on a rear driveshaft.. i've seen two piece driveshafts and some odditites but never a setup like that. All the time on front driveshafts but never the rear. Was it year specific or application specific? I'd be curious about the phasing of the driveshaft and balance as well. Is there any noticeable play in that joint if you try to move it up and down or side to side? Having an extra joint just seems like a place to cause problems. I'd think i'd have that removed and a proper length driveshaft made. Or explain it to me, because i'd like to understand the reason or the need. i'm genuinely curious!
now that you mention it, duh! on my part. Lol Many lifted blazers and broncos I have seen that setup, but stands to reason why i'd never seen them on most full size trucks. I do know as a kid growing up there were some seriously bad ass trucks around my parts when 42" swampers and then the 39.5 Bogger on monster wheels was all the rage. But i'm talking I was a teenager through that era. And to that point I do know a few guys that always were pissed about breaking u-joints and throwing driveshafts with that or similar setups. Maybe that was why? I remember a guy from our town had a '79 Bronco with 44" (I believe or maybe they were 42s as well) Gumbo monster mudders on it and it was so tall and so short coupled that he'd break a driveshaft quite regularly down at the sand bar and I know that one had Cardan joints in it for sure because I carried pieces to him more than once as a kid. My young mind always said it was the power that did it! LolThe double cardan on the rear shaft is a modification, not factory stuff. It's a common upgrade for trucks to combat driveline vibration created by the new operating angles after being lifted, they're mostly used on Blazers because of the really short driveshaft.
My thinking though would still be that in a normal or somewhat normal application, it almost seems "excessive" to install one and it would just give another place to cause issue. By looking at the pictures your driveline angles appear relatively "normal" ~actually somewhat flat. You've got an interesting combo for sure and coupled with the low gears i'd tend to agree that any little thing could show its ugly head. Makes me interested to know what the driveshaft shop will have to say.It's common on lifted trucks. I believe dodge used them in the past as well on non-lifted trucks. I could be wrong, that's what I was told. The benefit is that it runs smoother because the two joints cancel each other out. This also adds greatly to the life of the joints. In my case it's probably overkill and not needed. Since I was starting from scratch it wasn't much more $$$ to use a carden. For instance, I paid $550 for the entire shaft. The other "perceived" benefit is it's length doesn't count towards the shaft length. Since my setup (NV4500/205) is relatively short for a long wheelbase truck that was also a "perceived" benefit. To your point, yes, I can feel a minute amount of play in the joint and that's what caused me to notice the excessive endplay in the output shaft. However, I now believe the play in the output is normal and acceptable for this t-case. But, I think combined with this driveline it's a bad combination. Most lifted trucks that NEED this probably don't spend time on the highway at 70mph. For mall crawlers and offoad, you would never notice it. In my case with 4:56 gears that driveline is seriously humming on the freeway. I'm sure any imbalance will make itself known. Or--I'm completely full of S**T and grasping for straws.
But what size was the driveshaft in those rigs so equipped? Srs question cuz I have not worked on one.I get the critical speed thing but 4.56's and a 31"ish tire was a factory combo, I doubt GM would have built this combination if it was problematic.
I'm not sure they did. With an auto trans, the driveshaft would be 11 inches shorter. With a 465 manual trans, I'm guessing they used the two-piece shaft, at least in the longbed? How many people would drive 60+ with that combo in 4th gear with the engine screaming at 3200 rpm? Remember, I have a 4500 w/OD.I get the critical speed thing but 4.56's and a 31"ish tire was a factory combo, I doubt GM would have built this combination if it was problematic.
