Seat brackets..
BearKing
Black Hills
Bear
Do you guys know if the bench seats from 73-87 use the same seat mounting hardware? My 76 seat needs to be redone and when I took it out I saw that someone welded the bracket under it. It is terrible job and the springs inside are all rusted due to mice burrowing into the seat and pissing everywhere. Just going to hit the junkyards to find one to replace mine. Anyway, thanks in advance fellas.
ali_c20
Austria
Alexander
C20, K5
Afaik the brackets are the same, 73 - 87 should bolt right up to the floor. 73 - 80 is the first style, 81- 87 uses different frame, foam and cover.
SDJunkMan
Black Hills of South Dakota
Jeff
If you just need brackets, I have some on a trashed out 78 seat that is going to the landfill in the next day or so. Let me know ASAP and I will pull them off for you.
sparky77
