AyWoSch Motors
The Parts Guy
- Nov 6, 2020
- New Mexico
- Ayden
- K1500 Sierra
- 350ci V8
Okay, very odd question here. I'm sure I'll be told I need a new distributor, but curious what is going on.
So I have my 350 on a run stand so I can check everything out before it goes in my truck. Yesterday I hooked the exhaust up so itd be more quiet, so I could hear everything better.
Started up nice and quiet, and that's when I noticed the distributor is clicking pretty noticeably. The engine runs okay, but I do notice the idle isnt as smooth as it could be, and it has the slightest stumble on first rev from low RPM.
So I got out the timing light, unplugged the advance and capped of the vac port.
Timing was a little retarded, which I tought odd because I had set it before to 0°.
So I advanced it until it was reading about 8°- 10° BTDC at low idle and more about 12° at high idle. Engine was happy and had snappy throttle. Then I checked it a few moments later to be sure, and it had gone back to 0°. I advanced it once again just a little to see if itd stay, and sure enough it went back to 0°. Dont have a clue why.
The distributor hold down is tight, and it wont move at all when tightened down so I know it's not slipping, and the in a different position then when I started, so it has to be advanced, but its not reading that.
I plugged the advance back in, and its running fine. I let it idle for a while to hear it, and the engine is healthy, but the distributor is clicking alot.
I'm thinking of just buying a new one. But wondering why this is doing that, never heard anything like that before.
Dont know if its original to the truck, or something the PO put on, but shes old.
Please help, thanks.
