rebuilt sbc Oil pressure
Octane
Atlanta
Eddie
it had a warning light but it never triggered the light, i have my temporary gauge hooked up to it. and i am talking about the bypass that bolts up to the block with the oil filter adapter, im wondering if that can cause an issue.
Dont see how a bypass would cause issue.If it malfunctioned and didnt open with a clog, if anything pressure would go up.A clogged filter would go to bypass and maintain same oil pressure,just wouldnt be filtering oil.
Sam71395
Minnesota
Sam
V10 Silverado
thats what i was thinking, I just thought i would suggest it because maybe someone had a different experience, Im going to change the oil and filter, Im going to use 20w50 and see how it goes
Sam71395
Minnesota
Sam
V10 Silverado
hi all, heres the deal, I changed the oil and filter and put in 20w50, now I have 15psi at idle and 32-34psi cruising, and there was a minor lifter tick that went away also after the oil change so Im happy about that, so I am going to run with it this summer.
Sam71395
Minnesota
Sam
V10 Silverado
Hi All, kind of reviving my thread here, but I just had my valve cover off with the engine running all of the pushrods are spinning, the only thing i noticed is that one spins significantly slower than the others, there is no ticking or strange sounds, so is this somthing i should be concerned about?
If you have one pushrod spinning significantly slower than the others,you have one lifter not spinning as freely as the others. I hate to be chicken little here,but I'd pull the intake,spin the lifters by hand and make sure they all turn freely. A lifter that doesn't spin or spin well enough,will wipe out a cam. If you have to, polish some material off the O.D. of the lifter. First check the lifter bore for a burr or nicks,varnish etc.
mlparkey
Oak Lawn
Mark
Excessive clearance in camshaft bearings can definitely cause a lower than normal oil pressure reading.
Octane
Atlanta
Eddie
I had a 63 Impala in the 70s that the lifters were sticky,wouldnt spin.Every cam lobe was worn completely out
PDlane200
