- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
The u joints arent the issue its the carrier bearing. Aka drive shaft center support bearing.
The carrier bearing just slides right off... it might need a little persuasion, but not much. I thin when I did mine on my C20 it was a little pb blaster and tapping on it from the back side and it popped right off. You have to take the slip yoke apart, make sure you mark both sides so that you put it back together the same way it came apart.
