idahovette
- Aug 7, 2016
- Weiser Idaho
- Perry
- K20-K10
@78C10BigTen Ted according to my search the Carrier at Autozone is $21.99 part# HB88107A 1.375" stub shaft(where it slides on) The u-joints are $21.99 for Spicer greasable part# 5-3147X, all 3 or Moog #234 no grease zerks $18-19 each. If you knew how long overall the shaft was you could run some comparisons with rigs that have a fairly long shaft.... also they show a larger stub shaft diameter for the carrier brg. but I think it's for an extended cab only. It's 1.575 " diameter.
