Rough idle
martingmc86
california
martin
gmc sierra 1500
v8 5.0
I have an 86 GMC Sierra 5.0 I’ve noticed it idles kind of rough when stopped I replaced the spark plug to some acdelco rapid fires#1
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Im guessing its tbi? While engine running unplug coolant temperature sensor and see if it runs better [considering it don't die right away lol]
martingmc86
california
martin
gmc sierra 1500
v8 5.0
It’s broken and I can’t find the correct one
martingmc86
california
martin
gmc sierra 1500
v8 5.0
an 86 should be carb if still stock
Yes it’s it’s 100% stock with a brand new original carb I found a carb 0 miles from a GM plant that was throwing away new parts
martingmc86
california
martin
gmc sierra 1500
v8 5.0
Is it running rich? Loading up?
I tried adjusting the air/fuel mix screws it felt better but I still feeling a little rough I did a vacuum smoke test and no leaks detected
squaredeal91
Greg bush
1991 SB
Does it still have cat? Any exhaust leaks?
martingmc86
california
martin
gmc sierra 1500
v8 5.0
Yes still does original ones Im not sure of any exhaust leaks only the cat does look like it might have a leak when I hit it with a rubber hammer it releases dust in the middle of the cat
jkrenzel
