Rough country front shock mount
Gussie
Kansas
Corey
Hello friends; I'm installing RC shocks in front for my k20 2" lift and there is a lot of space to fill in between the mounting ears. I called RC and they sent me the rubber cone spaces which will fill in the gap however no extended metal eyelets are provided and when I called them, they said none comes with it. The shock as is does have a metal eyelet already installed btw. Anyone have experience here? Thanks
MarineOne
Western New York
That looks like a dual shock setup someone modified? Also I have rough country shocks and they definitely have metal sleeve in bushing
Gussie
Kansas
Corey
Here is the original shock setup. Looms like the eyelet extended beyond the bushing. I suppose I could cut an eyelet tube to fit the gap with the RC shock?
nvrenuf
Mobile, Al.
Some bushings have a long sleeve, factory had a spacer.
Gussie
Kansas
Corey
What worked was buying these bronze spacers from TSC...fit perfectly and solid.
Camar068
10 yrs Air Force
lil hijack, but on subject and thought a good place for it.
Is there a vendor that sells good replacements for the top shock mount? Mine are mangled and a turd to install the top of the shocks. I'll admit due to me and previous owners bending them.
Domarinolo
